280 user(s) are online (229 user(s) are browsing Forums)
cuisinartvette Any stock LTx intake #s out there?
Cannot find any reliable info on what these intakes flow
Flowed an LT1 after porting and did a before and after on an LT4 last week but kind of suspect on the before #. Just like to find what may be a ballpark accurate # on both
Maybe theres some info on the Edelbrock one also??
Posted on: 2014/9/19 15:58
BrianCunningham Re: Any stock LTx intake #s out there?
I have one, but it's bolted down to my old engine.
How about picking one up, flowing it, porting it and then sell them on an exchange policy?
Posted on: 2014/9/19 19:29
cuisinartvette Re: Any stock LTx intake #s out there?
Hows the autocross going Brian?
Thanks, I just ported and flowed an LT1 but didnt get a stock # just after
The LT4 Im working on did one before port and one roughed out do it again when Im finished. Just wanted to see what others came up with for comparison.
Hate to spend more taking it to yet a different flow bench if I have to. One ive been using appears very accurate but one # seemed high to me. Did it again and came out the same.
Still...
Last yr Ive done every GM Vette intake stock and aftermarket from 85-96 wanted a little more info to eventually put some hard data up just want it as accurate as possible.
Time consuming and expensive project lol.
Posted on: 2014/9/19 20:37
bogus Re: Any stock LTx intake #s out there?
I have a stock LT1 manifold if you need one for baseline.
Posted on: 2014/9/19 21:25
An offer to sell?
I have only an after# on the LT1 so far
Posted on: 2014/9/19 23:55
