263 user(s) are online (226 user(s) are browsing Forums)
Schrade Vac leak? Not MY mill...
Think your tune is perfect? And the obvious tune problems CAN'T hit you? That's what I thought too...
I've been starting mine with a weak battery since Spring. If I don't drive it for 2 weeks, battery is dead (even had a new one on the shelf for 7 weeks now). Daily starting was fine.
Saturday, I tried to crank it after an idle week. It struggled, and backfired up the intake (FOREfire?). Fire, AND detonation pressure, in the intake.
Big deal - right?
Vac hoses get old. You'd think that vacuum should seal small age-cracks - sort of. At worst, collapse them. But NEW vac hoses and caps?
What about detonation in the intake? I heard a pop, like a rubber band snapping. Then, I JUST HAPPENED TO SEE OIL SMOKE SEEPING FROM THE SNORKEL, AND FROM A NEWLY CAPPED VACUUM PORT ('90 LT5 was built w/o valve stem seals, and an idle week will show this in start-up exhaust)
The detonation popped the end right off the vac port cap. If I hadn't had the hood up, I would NEVER have noticed that... Been thinkin' on that for a week.
New build? Full of new parts, and hoses? And you missed the distributor by 180'? Oops! "I got the distributor right, WTH is wrong NOW??? "
Check those hoses; old, OR new...
Posted on: 2014/10/23 14:35
bogus Re: Vac leak? Not MY mill...
new isn't better... I have been shocked about the QC of some of this new crap.
Posted on: 2014/10/23 15:52
Matatk Re: Vac leak? Not MY mill...
Good tip!
Posted on: 2014/10/23 16:24
