271 user(s) are online (235 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
« 1 (2)
istter1 Re: Check engine light
Bakersfield Ca
2336 Posts
Woodstock wrote:
Ìf the TPS is installed like pictured, you've got a wrong set up! Zhe TPS link is currently above the hook but it belongs below.
My son put it on wrong I put it in the correct position over 6 months ago before the install on super ram.
I agree good eye in picture. Dust storm in our area right now may last a couple days. Praying for rain. Vet covered in garage until dust storm blows over.
Thanks
Steve
jpg  IMG_20141014_201942.jpg (128.60 KB)
5144_543de99b7348e.jpg 405X720 px
jpg  IMG_20141014_201912.jpg (136.84 KB)
5144_543de9c68d3cb.jpg 405X720 px
Posted on: 2014/10/15 3:34
Carol Burnett
Bakersfield Ca
2336 Posts
Using a new multimeter and test tool from mid America best reading throttle closed I could get was .01.no change when throttle open. what volts should be from the connector wire unplugged from the sensor. .01 is what I get the bottom connector reads 5.01 Are my settings on meter correct
is the plug bad . I have an extra plug. When I have time tomorrow I will connect Datamaster and check that way
jpg  IMG_20141017_205247.jpg (87.46 KB)
5144_5441e901dcb90.jpg 720X405 px
jpg  IMG_20141017_205401.jpg (160.52 KB)
5144_5441e924a9572.jpg 720X405 px
Posted on: 2014/10/18 4:10
Carol Burnett
Matatk Re: Check engine light
As far as the wiring, ground wire is 0 and the reference (power) wire is 5 volts. The other wire will fluctuate with the tps movement.
This is not a corvette, but a good read on how to check tps:
http://www.enduringautomotive.com/tps/
Posted on: 2014/10/18 11:33
Bakersfield Ca
2336 Posts
Thanks wiring going to sensor ok. If I can get Datamaster going I will see what the computer sees. Thanks Matatk
Posted on: 2014/10/18 16:07
Carol Burnett
Bakersfield Ca
2336 Posts
Data Master shows no volts going to computer.
Will go play with it some more
jpg  IMG_20141018_115015.jpg (189.19 KB)
5144_5442bd545041e.jpg 720X405 px
Posted on: 2014/10/18 19:21
Carol Burnett
Bakersfield Ca
2336 Posts
no volts from tps
jpg  IMG_20141018_132155.jpg (153.36 KB)
5144_5442cd61bde63.jpg 720X405 px
jpg  IMG_20141018_124714.jpg (155.85 KB)
5144_5442cd7bf3291.jpg 720X405 px
Posted on: 2014/10/18 20:29
Carol Burnett
Bakersfield Ca
2336 Posts
Installed new TPS set correctly.
After using Data Master engine cranks and does not fire. Data Master loaded it up.
Any thoughts. Did It damage the ECM..
Posted on: 2014/10/18 23:35
Carol Burnett
You need to check the wire from harness to ecm for a break/open. Check the harness to make sure a plug didn't pop out.
Posted on: 2014/10/19 1:16
Bakersfield Ca
2336 Posts
Haven't found any wire breaks or problems yet. I had a fire 3 years ago so double checking these is fun as I had to patch many wires.
ECM under warranty will be here Tuesday . It has a funny odor to it . Price just changed from 67 to 120 the old supplier had to many returns. Ya you guessed PEP Boys.
jpeg  1381716311932.jpeg (351.74 KB)
5144_5443253dd3a5c.jpeg 1200X1600 px
Posted on: 2014/10/19 2:50
Carol Burnett
Fsm should tell you which wire going in to the ecm is from the tps.
Posted on: 2014/10/19 3:11
Bakersfield Ca
2336 Posts
From Cliff Harris explaining the rough running in 10K problem to me
Some scan tools and cables put a 10K resistor across the A & B pins of the ALDL connector. In some cases there is a switch to take this resistor out of the circuit. In Diacom the switch is electronic and I can put it in or take it out.
Thanks Cliff just read this explains the rough running
From the shop manual (10K mode):
• Closed loop timers are bypassed
• EST (spark) is advanced
• IAC will control engine idle to 1000 RPM ± 50 RPM
• On some engines, canister purge solenoid will be enabled
• P/N restrict functions will be disabled
I am using Moates extreme with the switch for 10k
I log in 10k
I thought this video was a good reminder on checking wires
http://m.youtube.com/watch?v=pDzRsOpne_Q
jpg  IMG_20141003_224823.jpg (153.07 KB)
5144_544341528041f.jpg 720X405 px
Posted on: 2014/10/19 4:45
Edited by istter1 on 2014/10/19 5:39:17
Carol Burnett
Bakersfield Ca
2336 Posts
Well put the new ecm in lol
cooling fan clicks on/ won't shut off lol
engine cranks starts to fire. lol
I will never buy Pep Boys crap again.
I called the parts dept they do not deal with the vender my ecm came from to many returns. Lol
As a kid we always said at Pep Boys just go back until they give you the part that works.
Will use this weekend to search for problem or go to Pismo beach and play with the dogs
Posted on: 2014/10/22 5:17
Carol Burnett
I would look on ebay for a used ECM, you can find them under $50. The same ECM was used in the S10, etc, so they are out there. You are just swapping out the chips anyway.
As far at the 10k resistor, that has nothing to do with your TPS problems, which is why I didn't comment on it initially.
Posted on: 2014/10/22 13:01
Schrade Re: Check engine light
Testing TPS with paperclip backprobed to TPS output to ECM.
Posted on: 2014/10/22 14:12
Chuck, he has that little harness you connect in to check the tps. Steve said he has power to the tps but no power at the ecm for position.
Posted on: 2014/10/22 14:51
Bakersfield Ca
2336 Posts
Dam shop manual is here some where. Looking for wiring diagram.
Can't find it yet on my bishko service manual.
Posted on: 2014/10/23 3:15
Carol Burnett
Bakersfield Ca
2336 Posts
Dam a lot of vehicles used that ecm
Vehicles That Use A 1227165 ECM
Home
Year Vehicle Engine Notes
1987-90 Astro/Safari van 2.5L 4 cylinder
1987-88 Blazer S10/Jimmy S15 2.5L 4 cylinder
1991 Blazer S10/Jimmy S15 4.3L 6 cylinder
1991 Bravada
1987 Camaro/Firebird 5.7L 8 cylinder
1988 Camaro/Firebird 5.0L 8 cylinder with MFI
1988 Camaro/Firebird 5.7L 8 cylinder
1986-87 Camaro/Firebird 5.0L 8 cylinder with EFI
1989 Camaro/Firebird 5.0L 8 cylinder with MFI
1989 Camaro/Firebird 5.7L 8 cylinder
1986 Cavalier/Cimarron 2.0L 4 cylinder with manual trans
1986 Firenza/Skyhawk/Sunbird 2.0L 4 cylinder
1986-89 Corvette 5.7L 8 cylinder
1987-91 S10/S15/Sonoma 2.5L 4 cylinder
1991 S10/S15/Sonoma 4.3L 6 cylinder
This information is from the 1980 - 1989 Hollander Manual
Posted on: 2014/10/23 3:30
Carol Burnett
Bakersfield Ca
2336 Posts
Hope this is the one.
gif  Page_6E3-A-38_Diagram_TPS.gif (60.18 KB)
5144_54488c0328875.gif 950X575 px
Posted on: 2014/10/23 5:03
Carol Burnett
Bakersfield Ca
2336 Posts
Put Datamaster on to see if it had a signal from the ecm. none Checking for connection got this . Nothing wrong with ALDL or plug suspecting bad ECM
docx batama.docx Size: 959.61 KB; Hits: 121
Posted on: 2014/10/25 3:26
Carol Burnett
Steve -
I am no expert with datamaster. I am not sure if that warning is because you are not on the right port, not using the right selection for your year, or because the ECM is in fact bad.
Did you trace the wire at the ECM connector to see if it is getting a signal from the TPS? That is step 1.
Posted on: 2014/10/25 11:38
Bakersfield Ca
2336 Posts
My guess only way you could get the "no PCM" error is if there is no data coming out on ALDL pin E.
The SES light work? It's controlled by the ECM so if it's working the ECM must be at least partially functional
No signal to c13
5v to c14 hot
prom would not seat in new ecm will have a replacement one in an hour
checked wires in passenger side loom all the way to plug in fire wall
Posted on: 2014/10/25 20:58
Carol Burnett
Bakersfield Ca
2336 Posts
New ecm in got signal from wire. Set tps .54. Fan did not come on and stay on happy. Did not want to fire. Taking a break will recheck everything in an hour.
jpg  IMG_20141025_161901.jpg (133.59 KB)
5144_544c31e710591.jpg 720X405 px
Posted on: 2014/10/25 22:47
Edited by istter1 on 2014/10/25 23:27:43
Carol Burnett
Bakersfield Ca
2336 Posts
Past feeling stupid changed tps and I can't get it to stop impeading the throttel . The retainer on the tps is rubbing on the  screw .
This is the orgionsl tps a different throttle body.
jpg  IMG_20141025_182356.jpg (136.20 KB)
5144_544c506067270.jpg 720X405 px
jpg  IMG_20141025_182413.jpg (139.92 KB)
5144_544c50876d267.jpg 720X405 px
jpeg  20140115_153627.jpeg (263.04 KB)
5144_544c514c51624.jpeg 1200X1600 px
jpg  IMG_20141025_190839.jpg (77.02 KB)
5144_544c5a0e59767.jpg 720X405 px
Posted on: 2014/10/26 1:44
Edited by istter1 on 2014/10/26 2:19:03
Carol Burnett
Bakersfield Ca
2336 Posts
Will see if grinding down plastic shaft works. First thing in the morning
jpg  IMG_20141025_210031.jpg (93.38 KB)
5144_544c73caae717.jpg 720X405 px
Posted on: 2014/10/26 4:08
Carol Burnett
I thought you bought a new TPS?
Hopefully some careful sanding will give you clearance.
Posted on: 2014/10/26 11:51
Bakersfield Ca
2336 Posts
The new tps is the problem
will put it on when it warms up
Posted on: 2014/10/26 14:20
Carol Burnett
Bakersfield Ca
2336 Posts
Installed TPS works great now. A little sanding. Set to .54 without problem.
Cranks but doesn't want to start. This is now the easy part. I hope
Battery was weak on charger right now
Posted on: 2014/10/26 16:55
Carol Burnett
Bakersfield Ca
2336 Posts
FIRES UP RUNS GREAT . Thanks to all of you that helped me .Fixed a lot of problems I didn't know I had.
Posted on: 2014/10/26 18:45
Carol Burnett
« 1 (2)
