222 user(s) are online (178 user(s) are browsing Forums)
GRIS, more...
The ...
mscott67 Vibration @2100 rpms
6 Posts
Just bought another vette 92 this time and at about 2000-2100 rpms it feels like a vibration in the engine...Not sure where.
Happens in all gears and in neutral with clutch in or out.
Not sure if it is just a rattle in the exhaust or something.
Anyone ever have the same issue?
Any place to start checking?
92 with the LT-1 6 speed
search the fourms but found nothing
Thanks
Posted on: 2006/10/5 21:17
red_johnny RE:Vibration @2100 rpms
almost sounds like the classic exhaust note that happens around that RPM range.
Posted on: 2006/10/6 1:05
CasetheCorvetteman RE:Vibration @2100 rpms
First thing id look at is that everything is nice and tight, balancer and flywheel, as well as all belt driven accessories, if you think it may be an accessory, pull the belt off and try it to see if its still doing it. Check all the exhaust hangers, cats and mufflers too.
You dont say how bad the vibration is.....
Posted on: 2006/10/6 14:58
6 Posts
Pretty annoying, I will try that this weekend thanks.
Checking the flywheel? any other way besides pulling tranny?
Thanks
Posted on: 2006/10/6 16:20
Check everything else first, if if nothing helps and you find no other solution, then think about flywheel. I am not sure if the manual has an inspection cover like the auto, if it does, it should be pretty easy to check ;)
Posted on: 2006/10/7 14:10
6 Posts
How can you tell if the balancer is bad>
Thanks
Posted on: 2006/10/7 18:14
6 Posts
OK, Thanks for all the help.
Pulled the belt off....No vibration
Fliped the belt inside out and put it back on ...no vibrations....
Drove the car...no vibrations.....then turned the air on...now it back.
Could the belt be streched out...think a new belt would solve the problem.
Or is the another issue I need to look into?
Thanks
Posted on: 2006/10/7 19:28
6 Posts
Thanks
Posted on: 2006/10/7 19:29
Got ya, 92 with double sidded ribbed belt? If it was me, id see if you can get a kit to change to the 94 belt, they are only ribbed on one side. You could try a new belt, and if it still does it, check the A/C compressor and make sure its tight, make sure the pulleys all line up as good as they can. Is there any sign of the belt wearing worse on one side?
Posted on: 2006/10/9 13:02
could be that the ac compressor is starting to wear but I would go with a new belt first.
Posted on: 2006/10/9 13:36
mscott67 RE:Vibration @2100 rpms
6 Posts
Replaced the belt today,..... vibration is not as bad but still there....
a/c blowes very cold could it still be worn?
Posted on: 2006/10/19 16:24
Could be, but dont just go ahead and replace it without any solid evidence to point a finger at it.
Posted on: 2006/10/19 16:32
I agree with case. Maybe you can find a buddy who has the same and swap it in to test it
Posted on: 2006/10/19 22:29
Thats a bloody good mate if you can find one that will swap A/C compressors with ya!!!
Give the power steering pump pulley a wriggle and see if its tight, also make sure the A/C compressor is tight and straight first
Posted on: 2006/10/20 13:11
hulagan808 Re: Vibration @2100 rpms
hawaii, maui
58 Posts
belt tensioner or idler pulley going? aloha
Posted on: 2008/6/30 20:13
88 vert, gen 7, superram, blah blah blah for days
