239 user(s) are online (204 user(s) are browsing Forums)
The ...
TommyT-Bone 99 Yukon front end question
Thanks in advance. I have to order some parts for the front end of my Yukon.
Upper and lower ball joints. (Done)
Upper control arm bushings (Done)
Inner and out tie rods (1 of each? Correct?)
Pitman Arm (1 correct?)
Idler arm (1 or two?)
QUESTION ANSWERED. THANKS FOR LOOKING
Posted on: 2015/1/23 0:03
Edited by TommyT-Bone on 2015/1/23 12:33:32
bogus Re: 99 Yukon front end question
that all sounds correct to me.
I would have to crawl under mine to count the parts... I don't remember there being to idlers or pitmans.
Posted on: 2015/1/23 0:04
TommyT-Bone Re: 99 Yukon front end question
Here's what I was getting.
jpg  001.jpg (292.10 KB)
852_54c1940c14702.jpg 1700X2338 px
jpg  002.jpg (254.88 KB)
852_54c1941b34edb.jpg 1700X2338 px
Posted on: 2015/1/23 0:21
Hhmmmm 15 piece rebuild set
This is a New 15 Piece Suspension Set Containing:
2 Front Lower Ball Joints:
2-K6445
2 Front Upper Ball Joints:
2-K6292
2 Front Outer Tie Rod Ends:
2-ES2836
2 Front Sway Bar links:
2-K5252
2 Inner Tie Rods:
2-ES2837
1 Pitman Arm:
1-K6335
1 Idler Arm:
1-K6447
http://www.ebay.com/itm/15-Piece-Susp ... sh=item20d5cff87e&vxp=mtr
Posted on: 2015/1/23 4:07
This is just for me to compare
15 Piece Complete Suspension Kit
Fits Front Upper/Lower Driver & Passenger Sides
*2WD Models Only*
2 Front Upper Ball Joints - K6292
2 Front Lower Ball Joints - K6445
2 Front Stabilizer Bar Link Kits - K5252
1 Pitman Arm - K6335
1 Idler Arm - K6447
2 Outer Tie Rod Ends - ES2836
2 Inner Tie Rod Ends - ES2837
2 Adjusting Sleeves - ES2004
1 Idler Arm Bracket Assembly K6532
Posted on: 2015/1/23 4:43
This is what I bought.
Local seller, return policy.
http://www.ebay.com/itm/360529079719? ... geName=STRK%3AMEBIDX%3AIT
Posted on: 2015/1/23 12:28
BillH Re: 99 Yukon front end question
Hit or miss on the quality of OE, especially the ball joints.
That being said, half the Moog stuff is also made in China (but probably better quality).
Funny that GM kept the old style steering on the Yukon's thru 2000 but changed the pickups to rack & pinion.
You're going to have your mechanic do the install right?
Posted on: 2015/1/23 14:53
GM does that, Bill. They will do the truck first, then the following year, do the SUVs.
They did that again this time around... trucks in 2014, SUVs in 2015.
Posted on: 2015/1/23 16:49
Yep. I'm just gathering the parts.
Posted on: 2015/1/23 18:13
Good, using a spring compressor on those big springs is a tad dangerous.
Posted on: 2015/1/23 18:23
