220 user(s) are online (182 user(s) are browsing Forums)
The Natio...
BrianCunningham drip from tranmission cooler line 2009 Silverado 2500
Meet a friend who was getting her car serviced today
figured since I was there I'd get the oil changed on the Silverado
During the inspection they noticed a drip coming from the transmission cooler lines
They wanted $600 to change it w parts
I priced a new line $120
You can't just tighten the line up
they're quick connect
w3ird??
Of course it's 10 degrees out
so take a change an change it when it's warmer
or go ahead and them?
Posted on: 2015/1/23 17:56
TommyT-Bone Re: drip from tranmission cooler line 2009 Silverado 2500
How many drips to a quart? Maybe it's a cold weather drip. You can wait on that I think. End of March is right around the corner. Now if you have a leak that's another story.
Posted on: 2015/1/23 18:12
bogus Re: drip from tranmission cooler line 2009 Silverado 2500
I'm with Tommy on this... how fast is the drip?
You may also be dealing with a bad o-ring... something worth checking.
Posted on: 2015/1/23 20:16
