222 user(s) are online (181 user(s) are browsing Forums)
sophie 85 booster in 84
Findlay, Ohio s of toledo oh
42 Posts
Will a 85 brake booster work in a 84? Thank you Craig
Posted on: 2008/3/12 18:20
toptechx6 Re: 85 booster in 84
south Florida
362 Posts
All I can tell you for sure is that the GM part numbers are different.
84 14046849
85 10097670
Posted on: 2008/3/12 20:25
CentralCoaster Re: 85 booster in 84
Isn't the 84 steel and the 85 plastic?
I thought some guys were putting the 84 into their 85s because it was more durable.
Posted on: 2008/3/12 21:22
sophie Re: 85 booster in 84
42 Posts
Called Pirate Jacks today as they had a listing for a 85 booster it was metal and looked like the 84. asked them if 85 worked in 84 they said no but no reason why.They don"t have a listing for 84 booster.they said they built there boosters in USA.Just trying to stay away from Cardone prod. Thank You Craig
Posted on: 2008/3/12 23:05
CasetheCorvetteman Re: 85 booster in 84
My mate's early 84 has a plastic Girlock booster in it, and its exactly the same as the plastic Repco boosters, and the same again as the plastic PBR boosters. I dont know what is different if anything, but if its going to be anything, itll be the master cylinder that will be different.
Posted on: 2008/3/15 1:43
