301 user(s) are online (44 user(s) are browsing Forums)
Ultraman, more...
The Natio...
istter1 Throttle Position Sensor & clutch slip in third gear
Bakersfield Ca
2336 Posts
Code 22 came up and found out it was suddenly bad. (1 year old). After fixing the code 33 a few mounts ago suddenly a Autozone sensor goes out.
I replace it with a new one and the 383 stroker has more power then ever. Code 22 cleared and engine idling correctly.
I am in the country so I want to see if acceleration is any better. 1st and second like gang busters. I go to third but I don't punch it in third about 70 I punch it and it sounds like the clutch slips until I let off gas.
I repeat the same thing. Similar results. One more time but in third I smoothly press the pedal of the tko 600 and no slippage.
Any thoughts.
Posted on: 2015/6/8 0:44
Carol Burnett
Schrade Re: Throttle Position Sensor & clutch slip in third gear
Could ya' smell it cookin'?
Posted on: 2015/6/8 11:38
bogus Re: Throttle Position Sensor & clutch slip in third gear
that's interesting, but I am wondering if you smoked it in a lower gear...
Posted on: 2015/6/8 16:16
CentralCoaster Re: Throttle Position Sensor & clutch slip in third gear
There's nothing special about 3rd gear vs any other gear as far as the clutch goes. Other than the tires are more likely to spin before the clutch in lower gears. Although you would have noticed that.
Posted on: 2015/6/8 18:01
istter1 Re: Throttle Position Sensor & clutch slip in third gear
Bakersfield Ca
2336 Posts
Clutch has no problems unless I drive stupid so I plan on being a little more careful. Unable to smell clutch Spun for only a second or so each time. only about 6000 on this clutch
Posted on: 2015/6/8 23:25
Carol Burnett
6 speed? I guess the currently available pressure plates are pretty weak. I have an oem zr1 unit in mine and have never had slip at the strip or otherwise although I dont have any power adders either.
Posted on: 2015/6/9 2:10
Bakersfield Ca
2336 Posts
5 speed
Posted on: 2015/6/10 4:24
Carol Burnett
