232 user(s) are online (152 user(s) are browsing Forums)
jhammons01 Cordless Drill
I was changing out my Power steering pump and it turned into a Smog pump....but that is another thread (see my thread in C4 Tech)
Anyway, I do a lot of Contract work on weekends. I've become so accustomed to using my cordless drills for tightening nuts and bolts for speed.
When I drop back and start working on my car, it seems odd at first but really, using those drills makes things so much faster......hooking up the air and using the air ratchet quickly points out the cumbersome air hose dragging all over the place. Not to mention the air ratchet only goes to 40 pounds anyway. The Drill is not much further behind that. so if you need to torque it, you have to change tools anyway.
When I'm assembling, you'll find one drill with a ~16mm socket on it in my left hand and a 6mm Allen in the other drill in my right hand. get 'em lined up and squeeze the trigger......done.
One of my buds from the contracting job uses an impact drill...that thing is a bit slower bit it will torque it down for you if you let it...
Well I'm not really saying much...just bringing it up as I think I'm the only one I know that would use a Drill for these types of jobs. I kinda wanted to see what you guys thought.
Posted on: 2008/3/13 4:29
MAXXWRENCH Re: Cordless Drill
COLORADO
118 Posts
OH YEAH....I HAVE 3 CORDLESS DRILLS AT THE SHOP...A SMALL DRILL FOR TIGHT SPOTS & 2 LARGER ONES...USE THEM ALL THE TIME ESPECIALLY DOING INTERIOR WORK & BODY WORK....SAVE LOTS OF TIME NOT AHVING TO MESS WITH AIR HOSES & SUCH
Posted on: 2008/3/13 4:45
ONE SHOT, ONE KILL, I WIN
CSS996 Re: Cordless Drill
Mega Guru
Central PA
3644 Posts
Uh oh, look out!
Case should be along shortly...
Posted on: 2008/3/13 14:30
Currently "Between Vettes".
CentralCoaster Re: Cordless Drill
The drill is useless though if you don't have a bunch of clearance. I guess an angle drill would work, but really the air ratchet fits almost as many places as a regular one. You are right that the torque rating is really disappointing on it though. I got the most expensive one I could get and it does 40 ftlbs on a good day.
Posted on: 2008/3/13 15:06
jhammons01 Re: Cordless Drill
There is this thing....it's called a "Swivel"
it goes on the drive before the socket......
I am just giving you shit
Yes the clearance hampers most efforts. But four easy to reach 10mm screws......sure is quick with that drill.
Posted on: 2008/3/13 15:18
