251 user(s) are online (138 user(s) are browsing Forums)
jonszr1 ok where is underhood fuse block 1 that contains the 30 mp.......
Lone Pine, CA
fuse for the blower motor. is it one of those fusable links??????? I even took the battery out to find it . did find the probem with the cooling fan . a brek in the wire ofone of the fuseable links .or is it invisible hehe
Posted on: 2015/7/3 1:25
Matatk Re: ok where is underhood fuse block 1 that contains the 30 mp.......
I posted a link in your other thread.
Did you test for 12v power at the blower control module?
Posted on: 2015/7/3 2:25
jonszr1 Re: ok where is underhood fuse block 1 that contains the 30 mp.......
Lone Pine, CA
yes I did . the other link doesn't show where that little 30 amp fella is
Posted on: 2015/7/3 2:52
The link has a picture. The fusible link is located off the starter lug underneath the car.
I am not sure by your above answer - is there 12v at the blower control module? You should have a constant 12v there.
Posted on: 2015/7/3 15:29
Lone Pine, CA
hope this isn't a stupid ?I am not the smartest guy with electrics. by the blower control module do you mean the one that is on top of the air box. I haven't cked that one . would I ck the red wire for power . sorry for so many ?s I wish a had more money to have someone do it for me but I am just a old fella on ssi and trying to keep my pride and joy .but mybe it might be time to think about selling her and getting true old guy car .....
Posted on: 2015/7/3 18:42
On my 89 there is a two wire plug next to a three wire plug. Pull the two wire plug, and check the red wire for 12v. Set your multimeter to volts (most likely 20v) and check the red wire with the red probe and put the black probe on a ground. It should read battery voltage. If you show battery voltage, the fusible link is not the problem.
Posted on: 2015/7/3 20:54
Lone Pine, CA
well I found the problem the red wire connector on top of the airbox didn't have good connection.it melted part of the weather pac connector . I put a new connector on it and all is well . thankyou to everyone for being patient with a old man who is electricly chall.enged
Posted on: 2015/7/4 1:13
Excellent! Glad it's fixed.
Posted on: 2015/7/4 2:11
bogus Re: ok where is underhood fuse block 1 that contains the 30 mp.......
hurray!!!
Posted on: 2015/7/5 18:14
