298 user(s) are online (248 user(s) are browsing Forums)
[IMG]http:/...
Frank Cigarette lighter power
188 Posts
Lighter doesn't work so I went to the fuse panel. To my surprise I don't have a fuse that is labeled "lighter". Manual doesn't specify either. Any ideas? Looks like I'm going to check all the fuses and see which one is bad.
Posted on: 2015/7/24 21:26
Matatk Re: Cigarette lighter power
22803 Posts
Off the top of my head check acc, ctsy, or rad.
Very likely it is corroded inside. You can disconnect the assembly, unscrew it and separate it into 3 pieces and clean it up.
Posted on: 2015/7/24 23:18
Frank Re: Cigarette lighter power
188 Posts
Got her fixed. It was the connection at the lighter socket. Should-a checked that first......Thanks for your input.
Posted on: 2015/7/27 20:25
