223 user(s) are online (184 user(s) are browsing Forums)
Icebeer Mass Airflow Issues
Buffalo,NY
1 Posts
Purchased a 1986 convertible not running. When I got it home i realized that the previous owner installed a 383 crate motor. The air cleaner and mass airflow are restriction the airflow. there isnt much out there on the aftermarket and I still have to use the stock mass airflow. Anybody know of a conversion to a larger mass airflow or to a map sensor?
Posted on: 2016/6/19 17:13
bogus Re: Mass Airflow Issues
I would be shocked if the MAF was causing restriction on a 383 crate. That MAF is able to flow over 1000 CFM.
The air filter? another story... but the MAF? I have me doubts.
If anything, the 383 still has the stock TPI intake, THAT is your air restrictor...
More details on the build would be helpful.
Posted on: 2016/6/19 19:41
BrianCunningham Re: Mass Airflow Issues
^^^ agree
TPI intake was designed for a 305ci engine
Need to at least get bigger runners
Posted on: 2016/6/19 22:52
Matatk Re: Mass Airflow Issues
The MAF and air cleaner don't restrict the motor, as stated above. I have the stock MAF and air cleaner with a cut lid on my 383 and it has plenty of power.
Welcome to the site and let us know if you have any questions about getting the car running.
Posted on: 2016/6/20 11:46
