483 user(s) are online (45 user(s) are browsing Forums)
Schrade Power Seat Tranny Service; Track Swap...
HERE ... WE ... GO ... AGAIN ...
Common C4 failure - Power Seat Transmission / Track Failure.
(while I contemplate Sill Trim...)
Remove Seat CUSHION Base.
Remove Seat from Track Assembly.
jpg  IMG_8692c.JPG (929.35 KB)
1687_5796490bebcdf.jpg 2364X1773 px
jpg  IMG_8696c.JPG (912.53 KB)
1687_57964a92add43.jpg 2264X1698 px
Posted on: 2016/7/25 17:24
Schrade Re: Power Seat Tranny Service; Track Swap...
Seat out. No goodies, no corner jam, save some dusts.
Access to Seat Mount bolts...
jpg  IMG_8698c.JPG (909.81 KB)
1687_57964f29c4d6a.jpg 2214X1661 px
Posted on: 2016/7/25 17:44
Seat out, cleanup (ALWAYS BOLTS BACK IN HOLES, NUTS ON STUDS, ETC).
And Post Mortem, post eviction, should be VERY interesting here...
jpg  IMG_8699C.JPG (981.58 KB)
1687_5796542630cdc.jpg 1864X1398 px
jpg  IMG_8700C.JPG (920.57 KB)
1687_579654ad0150f.jpg 2364X1773 px
Posted on: 2016/7/25 18:04
Goodies sent by buyer...
jpg  IMG_8702c.JPG (886.05 KB)
1687_579656005c695.jpg 2464X1848 px
Posted on: 2016/7/25 18:10
Track / Tranny in.
Note Zip Tie to prevent chafing harness under seat. Dry run good, EXCEPT polarity for Forward Backward is REVERSED!!! Connector cleaned, DE Grease, KEYED, so NOT in backwards...
jpg  IMG_8704c.JPG (943.04 KB)
1687_579658e5a80ea.jpg 1864X1398 px
Posted on: 2016/7/25 18:25
Anyone see anything wrong there?
So the Seat wasn't close to matching up Mount Bolts. Hmmm...
And the Polarity is BACKWARDS.
Hmmm................................
Are the assembly in backwards? ALWAYS WATCH ME WRENCH THE WRONG WAY HERE.
Schrade wrote:
Track / Tranny in.
Posted on: 2016/7/25 18:39
Wow; what a wrestling match WWE Survivor Series getting seat back onto Track Assembly.
It's obligatory that ONE bolt will cross-thread. Then you have to run THAT bolt into a good hole, AND IT GETS HOT, even greased. And run a GOOD bolt into the first hole. Monkey see, monkey do - HOT, but in correctly.
In. Forward seat with Forward switch, imagine that, and REARWARD TOO, miracles don't stop !
3 hours, 2 mixed drinks, 5 Chrome wrenches, one socket, one hammer, and a
Solved.
Post Mortem on OEM Track later...
jpg  IMG_8707c.JPG (893.80 KB)
1687_57966fe07514e.jpg 2164X1623 px
Posted on: 2016/7/25 20:02
Edited by Schrade on 2016/7/25 20:48:16
GOLDCYLON Re: Power Seat Tranny Service; Track Swap...
Peoria, Arizona
23 Posts
What no lose change? I found $50 bill stuffed under there from PO when I pulled my drivers seat.
I bet the transmission is roached on the pulled unit. It never seems to be the motor.
Posted on: 2016/7/25 20:11
bogus Re: Power Seat Tranny Service; Track Swap...
I agree...
Inside the gearbox is a nylon support that holds all the gears. That breaks. Gears get eaten.
Junk design, if you ask me.
Looks like a nice job!!!
Posted on: 2016/7/25 21:36
Any pics of breakdown there ANdy?
I think Darryl said you have to drill rivets to open it up?
I agree...
Posted on: 2016/7/25 22:06
I will check... don't have any with me now!
However... it is a ton of rivets...
Posted on: 2016/7/26 1:07
Peoria, Arizona
23 Posts
IMHO destined to fail just like those handy pellets in the headlight mother however hard to complain about a 26 yo vehicle. Things do wear out with time and general wear. Well done Chuck
Posted on: 2016/7/26 4:09
GOLDCYLON - 91 ZR-1 #2014
Resized Image380 P&P&PCed,Ported Heads,Jeal headers,/Corsas/FIKSE FM-5s /LED TLs, HID Projectors,/R Baer Eradaspeed Rotors with Wilwood 6 piston front calipers
Thanks! Couldn't (probably wouldn't have, till another time) without ya' there..........
Now, back to the sill trim here.
Posted on: 2016/7/26 15:58
