286 user(s) are online (255 user(s) are browsing Forums)
pappyfreebird ok here i go again
1028 Posts
84 n took her fer a drive n dig it bigtime....but had prolem wid coolin fan runnin soon as turn key on...was the sensor in the air comp ...had tech school boyz replace it n fill freon...point car runs 195...but 40 here ...so runnin wid thermostat dig...so i let it idle (out of curiousity) n no fuggan fan up to 230 degrees..dint ground the sensor( between 6-8 yet) and wont turn on wid air con. switched on either and neither does compressor..but fan runs ifn i cross at relay..oh n did put in new relay cause was here ... no diff...prolly good thing im a curious cat heyhuh..now maybe i find n fix befoe it gits warm n i really wanna use this beast of a mobiiile...i have a haynes n ony temp talk in it is fer 85 sez ecm closes 239 n overide to closes at 239...now i thunk they were like 228 n posed to turn on ...any comments ... besides learn ta write ...er buy a honda wahahaha
Posted on: 2008/3/21 0:11
Touringmike Re: ok here i go again
Sussex,Wi
569 Posts
That's what I did.
(Bought it for the wife)
Posted on: 2008/3/21 2:09
´85 4+3
pappyfreebird Re: ok here i go again
1028 Posts
hey t mike have you done your own tranny oil changes?? how was it (gitton under it er gittin it high nuff) ever had any issues with that 4+3?
Posted on: 2008/3/21 12:24
1028 Posts
ok so it needs to heat to 238 before fan comes on..well hey thanks pappy ...now that makes more sence why wouldnt come on at 230..yea that be why dude ...yeup must be heyhuh..id sure bet it is..well i sure hope so...doesnt answer the question on ...is fan posed to run wid air con. on ...or ony when air con. compressor runs...but hey im gitton some where...(yeah like the fuggan looney bin) wahahahaha..i dont mind talkin to myself ...its the arguin that sux...hey happy easter to you rednecks
Posted on: 2008/3/21 18:54
pianoguy Re: ok here i go again
Har! Happy Easter to you, too ;-)
I don't have much help to offer - I know these things can run hot, but have you checked to make sure your radiator isn't clogged with debris? If it is, blow it out with compressed air from the engine side.
Posted on: 2008/3/21 19:20
1028 Posts
thanks piana man...she runs 195 but only 40 here as you know...was just curious ifn fan would come on when it does warm up...be good
Posted on: 2008/3/21 19:26
