272 user(s) are online (199 user(s) are browsing Forums)
Does it work?
stitch abs C4 1993
sweden
1 Posts
Abs service is on all The time,wheel sensors ok,Can not find the reley,it is not
located behandling the seat
Posted on: 2016/10/5 18:20
donhall Re: abs C4 1993
297 Posts
Welcome to the C4 Guru forum:
Check the brake fluid reservoir.....fill, if necessary.
Reservoir sensor is very 'sensitive', so keep the reservoir full.
If a full reservoir doesn't solve your ABS light problem,
you might check for DTC (diagnostic trouble codes).
Posted on: 2016/10/5 19:06
Matatk Re: abs C4 1993
Is it only the ABS light? Check the fluid level as Don suggested.
Posted on: 2016/10/5 23:46
bogus Re: abs C4 1993
There is a way to check the code... I will post it later.
Welcome!!!
Posted on: 2016/10/6 15:48
