istter1 | installing new IAC on 87 | ||
Vehicle hard starting unless warmed up. Reset IAC worked a little better. I know it is in the manuel. But the site seems very slow on conversation lately. Do i reset computer after installing new iac?
Posted on: 2016/12/30 18:26
CorvetteBob | Re: installing new IAC on 87 | ||
If you've already gone thru the procedure to reset the IAC, then it certainly won't hurt to allow the computer to go back to its default startup settings.
Besides, it doesn't cost anything to try. |
Posted on: 2016/12/30 20:34
istter1 | Re: installing new IAC on 87 | ||
cool
Posted on: 2016/12/31 5:18
Matatk | Re: installing new IAC on 87 | ||
Did you try cleaning the IAC and TB before replacing anything? I'd try that and then the base idle relearn.
Posted on: 2017/1/1 13:38
I did all that. Had minor improvement. Ordered IAC went to install it and found my son had borrowed my deepset 33mm socket. Got in vet to borrow my socket back. Engine fires right up. All day yesterday fired right up. So now it is a wait and see. So for now the new iac is in my parts rack. |
Posted on: 2017/1/1 16:50
Might be unrelated to IAC. Something to consider.
Posted on: 2017/1/1 17:13
i agree with you
Posted on: 2017/1/1 18:08
Several things can cause hard starts. Is it a long cranking time? What are the symptoms?
Posted on: 2017/1/1 19:10
like it isnt getting gas.about 10 to 15 sec usually starts on 3rd crank
Posted on: 2017/1/1 22:57
Have you tested fuel pressure?
Posted on: 2017/1/4 0:07
done that
Posted on: 2017/1/4 15:29
You've done that recently or checked it while the problem occured? What is the fuel pressure prior to and during cranking?
Posted on: 2017/1/5 2:38
