311 user(s) are online (285 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
lezpayne Corvette 1980 rear diff posidrive
utah
2 Posts
Technical question ! I am rebuilding the rear diff Posidrive on my 1980 corvette, i have replaced the clutch plates with a new kit. My question is how tight should this be to turn in the vice. Is there a set torque value that i could expect to have before it begins to turn.
Posted on: 2018/3/6 19:01
Matatk Re: Corvette 1980 rear diff posidrive
22803 Posts
Welcome to the site!
Here is a pretty good article with some pictures and info:
http://www.superchevy.com/how-to/engi ... -and-c3-corvette-rearend/
From the article it states:
"10. Eddie checks the clutch clearances with a torque wrench a second time to ascertain proper clearance. The carrier should turn with some resistance, but not extreme effort. The resistance shouldn’t be any greater than 45-50 ft-lb as a rule."
Is that your question or something else?
Posted on: 2018/3/6 21:23
22803 Posts
Some more info I found online...not specifically mine.
The 80-82 is a Dana 44 (I've seen it called a Super Dana 44) and it's specific to those years.
These should be the torque values:
These values are directly out of the GM Shop Manual for the 1980 Corvette:
Pinion nut- 200-220 lbs. ft.
Ring gear bolts- 45-60 lbs. ft.
Bearing caps- 60-70 lbs. ft.
Carrier front support- 65 lbs. ft.
Carrier cover to frame- (sidemember bracket) 95 lbs. ft.
Rear spring plate to carrier- 45 lbs. ft.
Strut bracket to carrier- 30 lbs. ft.
Camber Cam- 130 lbs. ft.
Strut rod to spindle Support Attachment- 75 lbs. ft.
Drive spindle nut- 100 lbs. ft.
"Lubrication: To refill add 4 oz. of GM 1052358 additive or equivalent, then fill to level of filler plug hole with GM 1052271 or 1052272 or equivalent."
Posted on: 2018/3/6 21:40
lezpayne Re: Corvette 1980 rear diff posidrive
utah
2 Posts
Thanks, that's exactly what i wanted.
Posted on: 2018/3/7 21:09
rklessdriver Re: Corvette 1980 rear diff posidrive
I did this tutorial on inspection and rebuilding of the D44 Trac-Lock's a few years ago.
http://www.corvetteforum.guru/modules ... topic_id=17573&menumode=2
Posted on: 2018/3/8 18:02
