124 user(s) are online (100 user(s) are browsing Forums)
TOO_HOTT Dyno Day
25 Posts
I went to the Breathless Performance dyno day. Not many C4s there but I did see a few. A 1990 ZR-1 with 150 miles was there and even did a dyno run!
[IMG]http://i8.photobucket.com/albums/a49/TCBdaKING/HPIM2002-1.jpg[/IMG]
[IMG]http://i8.photobucket.com/albums/a49/TCBdaKING/HPIM2010.jpg[/IMG]
[IMG]http://i8.photobucket.com/albums/a49/TCBdaKING/HPIM2009.jpg[/IMG]
[IMG]http://i8.photobucket.com/albums/a49/TCBdaKING/HPIM2018.jpg[/IMG]
Posted on: 2008/4/7 22:14
tobijohn Re: Dyno Day
Palm Beach Gardens, FL
515 Posts
So what were your numbers?
Posted on: 2008/4/7 22:20
John
1996 LT4 coupe black/black
AIRFOIL FREE!
TOO_HOTT Re: Dyno Day
25 Posts
I haven't done a tune for my new set up and I'm using the PCM for Less tune from mu hotcam set up...but it still managed 350 to the wheels.
http://www.photoshow.com/watch/vV7jF3ED
Posted on: 2008/4/7 22:48
515 Posts
Jeez, what's the new setup? For that matter what was the old setup?
Posted on: 2008/4/7 22:53
25 Posts
The old "set up" LT4 top end, 52mm TB, EM longtubes, Hot Cam, Meziere water pump, tune from PCM for Less.
New "set up" Same as above except it now is stroked 383 forged and balanced rotating assembly, Ported and polished the LT4 heads, 30# SVO injectors Walbro fuel pump, MSD pro billet opti. I am using the same tune. It seems to idle and rev up fine. Drivability is exellent.
I'm scheduling to do a new tune...
Posted on: 2008/4/8 2:47
Matatk Re: Dyno Day
Sorry, just saw this post...should put down some great numbers!
Posted on: 2008/4/11 23:55
