Midnight85 | Bose sound problem | ||
I'm having trouble getting my front speakers to work with my Pioneer head unit so I am considering pulling all the Bose stuff out. Where do the rear speaker wires run? Will I have to pull all the carpet out to change these wires?
Posted on: 2008/2/6 2:58
HORSEPOWER! Some is good, more is better, too much is just right. |
Agent86 | RE:Bose sound problem | ||
If your not using an external amp, you may just want to use the factory wiring. It runs down the passenger side beside seat. I had to run new wires and required removing the rear carpet only. You can fish the wires under the front carpet and trans tunnel carpet.
Posted on: 2008/2/7 14:16
Midnight85 | RE:Bose sound problem | ||
Thanks Dan, if I can't get this
thing done today I will be tossing the Bose, I thought that's where the rear wiring went, I remember it a bit from when I replaced my carpet. I might try using just the factory speaker wires first. |
Posted on: 2008/2/7 16:00
Problem solved! Even though the
interface was made for my car, ??? We replaced it with a totally different component and it works like a charm. Boy am I glad, I didn't want to have to gut that Bose. My oldest son gets the car when I'm done with it so he can do it if he wants to. |
Posted on: 2008/2/7 22:18
skirlin | Re: Bose sound problem | ||
Midnight85, you installed a Pioneer HU and wired it into the existing bose system and it works well?
Posted on: 2008/4/10 5:23
There is no point in living if you can't feel alive. |
bogus | Re: Bose sound problem | ||
uh, yea, I am a little mystified.
Posted on: 2008/4/12 17:32
