337 user(s) are online (303 user(s) are browsing Forums)
red_johnny Go cart wont start
DARNIT!! I replaced the gas with some fresh stuff to make sure its good. Cleaned out the carb quick with some carb cleaner, replaced the plug and nuttin. Its gotta be a fuel problem. I wonder if I can get a new carb cheap locally? Either way the carb is coming off tomorrow and hopefully I will have it running by next weekend.
Posted on: 2006/12/10 3:37
bogus RE:Go cart wont start
I assume this is a Briggs?
do you have spark?
a few tricks....
1) remove the plug and heat it with a lighter.
2) hit it with some starting fluid, if it fires, then it's fuel. Otherwise, you have a spark problem.
3) If it's the carb, I would be it's the float... you don't need to replace it, unless the the needle housing is bad. I would simply hit the needle with some carb cleaner. If the needle is bad, then the housing might be, too.
Posted on: 2006/12/10 7:14
freakd RE:Go cart wont start
727 Posts
some one putwater inwith thegas, if i rmember, a complete rebuild,orgeta nwone, cab thatis :thumbright:
Posted on: 2006/12/10 11:02
red_johnny RE:Go cart wont start
Yeah, I think its the carb. I put gas into the chamber and after a pull or two it will fire a couple times. Plug has a nice bright blue spark to it Excellent tips bogus! I would have never have thought to heat up the plug to help it along! I did take apart the float and there is alot of build up on all the parts. I scraped off the needle but the spring on the back side of its in bad shape and dont look like its working anymore.
Posted on: 2006/12/10 16:47
cuisinartvette RE:Go cart wont start
Does it use a choke?
Posted on: 2008/1/1 7:07
CasetheCorvetteman RE:Go cart wont start
This is an older one!!
Posted on: 2008/1/1 7:33
