patgizz | LT1 intake on L98 - my thoughts | ||
i just got my LT1 intake last night and today i mocked up a gen1 block/heads to look things over some.
here is my biggest thought: why all the mods to the intake? with the exception of the 4 outermost bolt holes being on the wrong angle and needing fixed, what says not to just drill/tap the inner 8 bolt holes into the heads as opposed to grinding all over the intake? it would not leave you with unusable heads if you wanted to go to a typically patterned intake down the road because the new holes would just get covered up with gasket. with that said i'm sure i will modify the intake as opposed to the heads when the time comes, but it looks like an easier way to get it bolted on. so i picked up a B body intake/rails which i understand are the proper rails for a c4 L98 swap retaining the large cap distributor. even to pay someone to do the modifications to the bolt pattern if you can't do it and doing the rest yourself is a hell of alot cheaper than buying a miniram. |
Posted on: 2008/4/19 15:54
rayquayle | Re: LT1 intake on L98 - my thoughts | ||
Pat,
Where have you been all these years? Who's this handsome lad? And what is he doing with his other hand? :silent: |
Posted on: 2008/4/19 20:05
Ray Quayle in England '86 Indy PaceCar, 4+3 NCM Founder #2896 NCM Lifetime #672 Graduate of Gordon's School |
bogus | Re: LT1 intake on L98 - my thoughts | ||
Gee, Ray... you really think he is doing something perverted at the musuem??? during a dinner event?
As for the heads... here is my take - why remove unless you really have to? The intake is easier to work on, too. I think you will really like the LT1 intake. You may want to think about making up a remote EGR mount... the egr does two very important things - lowers the chance of getting detonation and keeps NOx in check. |
Posted on: 2008/4/20 18:23
