222 user(s) are online (188 user(s) are browsing Forums)
donandsandra Digital Dash Problem
4 Posts
Anybody seen a digital dash problem like this before? Ive been pulling my hair out trying to figure this out!!!!!!
I turn the key on the dash display looks great... Start the engine and the cluster goes goofy...
Check the video below.
http://www.youtube.com/watch?v=qdULEgJT8kw
Thanks Don
__________________
Vrooom nothing compares to a VETTE!!!
Save the wave!!!
Posted on: 2006/12/17 19:57
PeteK RE:Digital Dash Problem
The digital dash is prone to poor grounds. Gordon Killebrew has a book take explains how to run a new ground by tapping the ambient air temp switch mounted on the firewall, behind the brake pedal area. Hopefully someone with the book will chime in.
Posted on: 2006/12/17 20:12
red_johnny RE:Digital Dash Problem
This happened to me before with low voltage and a bad alturnator. I would check it out and get it tested.
Posted on: 2006/12/17 21:44
donandsandra RE:Digital Dash Problem
4 Posts
Thanks Guys for the great info.... I will have the alternator checked out.... if that dont work I will order the book.
Thanks A Million!!!!
Posted on: 2006/12/18 1:14
Let us know how it turned out then.
Posted on: 2006/12/18 1:21
4 Posts
Just repaired problem..... It was a bad coil... that was a weird problem...
Posted on: 2006/12/19 2:39
A bad coil, ignition coil?
Posted on: 2006/12/19 14:39
4 Posts
Yes ignition coil.... I replaced the coil last year. Car was in the paint shop for 7 months.. got it back and it had the problem.... I keep a list of everything I do to the car.. The last thing I did was replace the coil... Put the old one back in problem went away.... weird problem..
Posted on: 2006/12/20 14:34
WOW, that is a strange problem
Posted on: 2006/12/20 19:11
freakd RE:Digital Dash Problem
727 Posts
bad coil, thiat is interesting
anychance of you doing a tech tip for us??? :thumbright:
Posted on: 2006/12/26 13:09
