224 user(s) are online (163 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
Eagle223usa Interrmittent no start?
Guru with Eyes of Steel
God's country, Pa
197 Posts
I hit the key and the starter engages and just stops. Click. Starter? Solinoid? Any thoughts? The battery is new and fully charged (On this one anyhow!) Thanks Guys for any insight.
Posted on: 2008/4/24 0:29
God Bless America!
CentralCoaster Re: Interrmittent no start?
Just a click?
First check your battery cable connections, otherwise you may have a bad starter. Try tapping the starter with a hammer next time it happens and see if that changes anything.
Posted on: 2008/4/24 0:34
Eagle223usa Re: Interrmittent no start?
God's country, Pa
197 Posts
Battery is new and tight, Cables are new (GM) and I won't be able to get to the starter unless she's on jackstands! It's an LT1 ZF6. It will click, and nothing. If I hit the key a couple more times the starter will catch and she fires right up. The first thing I tried was a new ignition key, same result. I'm thinking solinoid. I'll check out the price of a new solinoid this weekend. Thanks Central Coaster.
Posted on: 2008/4/24 1:20
God Bless America!
MAXXWRENCH Re: Interrmittent no start?
COLORADO
118 Posts
EAGLE...BEFORE YA PUT A SOLENOID ON IT YA MIGHT AHVE SOMEONE MAKE SURE THERE IS NOTHING WRONG WITH THA ARMATURE WHILE YOU HAVE IT OFF & ALL...JUST A THOUGHT...BE A HUGE DRAG TO PUT SOLENOID ON & HAVE IT DO THE SAME THING...IF YA TAP IT WITH A HAMMER & IT TAKES OFF CRANKING OK THEN YA HAVE A PROB WITH THE ARMATURE...YOU WILL EVENTUALLY HAVE TO PUT IT ON STANDS ANYWAY...GOOD LUCK
Posted on: 2008/4/24 2:17
ONE SHOT, ONE KILL, I WIN
God's country, Pa
197 Posts
Replace or rebuild? Hmmm, $118 for a probably chinese replacement (worldwide) or $120 for the shop next to advance to rebuild it. I think I'll pull it and get it rebuilt by an American. No offense to anyone, I'll be in the garage. Thanks
Posted on: 2008/4/24 17:38
God Bless America!
God's country, Pa
197 Posts
Fixed, I'll be taking her to work tonight! Catch ya ! Thanks Maxx and CC, I just figured, ya know, for $120 I'd just have the thing rebuilt. They (Stellar Gen repair) stated It was just worn out. Thanks again!
Posted on: 2008/4/24 22:22
God Bless America!
