251 user(s) are online (213 user(s) are browsing Forums)
freakd my truck got hit friday
727 Posts
this is what hit me
now i have a shake in the rear end, driving down the road, i think the frame might be bent as well, he hit me so hard that his front bumper came off, he had to wire it up to make his vehicle drivable
Posted on: 2006/12/25 0:07
red_johnny RE:my truck got hit friday
OWCH, how did that happen?
Posted on: 2006/12/25 21:05
freakd RE:my truck got hit friday
727 Posts
i was going through an intesection, he had the stop sign, couldn't wait. looks like he bent my frame, which means the truck is totaled, it's a 2000,i keep it in real nice shape, especially for a northen truck.
i had a new fender put on that side 2 months ago
Posted on: 2006/12/26 12:49
bogus RE:my truck got hit friday
I doubt the frame is bent.
Don't let damage appearances cause you to think it's worse. More than likely, the wheel got wacked... the shimmy could be a damaged wheel/tire.
I would check the rear axle out, to be sure there wasn't any bearing damage.
even if the framw is bent, it won't cause a "shimmy." It would make it drive queer, but not shimmy.
Glad you are ok!!!!!
Posted on: 2006/12/26 18:13
