216 user(s) are online (165 user(s) are browsing Forums)
Marty LT-1 won't start after gasket replacement
Stafford, Va
2 Posts
My car is a 95 LT-1, it started to leak oil about three weeks ago. After a brief look over it appeared the oil was coming from the front upper portion of the engine. I broke the engine down and replaced the head/water pump/intake/exhaust gaskets, I also replace the Spark plug wires and spark plugs (gaps are good set at .050).
Once I had it all back together, the car wouldn't start. When I turn the egnition; the crank turns, plugs spark (atleast 1&8 fire only ones I checked), cylinder is getting fuel (smell it on plugs apon removal and fuel rail is pressurized), all sensors are pluged in.
Can anyone help me here?
Posted on: 2006/4/5 2:35
Rabbit RE:LT-1 won't start after gasket replacement
Sonoma, Ca
11 Posts
Marty,
Have you attempted to pull any codes? Easiest place to start I think.
Posted on: 2006/4/5 22:50
Marty RE:LT-1 won't start after gasket replacement
Stafford, Va
2 Posts
Rabit,
I have not pulled the codes. I will give that a try.
I checked all ingnition wires, coil, and distributor last night. All voltage and ohms were within specs.
Thanks, I will let you know what happens.
Posted on: 2006/4/6 19:55
bogus RE:LT-1 won't start after gasket replacement
spark... fuel... no fire... that's odd.
Posted on: 2006/4/18 20:13
Arisa RE:LT-1 won't start after gasket replacement
Laurel DE
37 Posts
This is going to sound SO stupid but I'm saying it from 100% personal experence. Do you have the coil control plug and the (I think MAP it's something close to the coil) plugs reveresed. I know they are supposed to be different but on Arisa they aren't. I spend three plus weeks beating my head, cussing and buying a lot of parts I didn't need to discover this was the problem. Yes I would get random spark but it would never fire up. I swapped them and poof all was good again. I couldn't decide if I should cry or laugh when it was all done.
BTW as a sidenote...I doubt you will find any codes of relevance. Most won't register till the engine RPM's are over 300. Not all but a lot....
Posted on: 2006/5/10 12:27
good point. I didn't know the coil could be that big a pain.
And yes, the PCM won't return a code until it is running. That is an upside to the LTCC. It has a fault code that will appear if the engine does not start. Very usefull.
Posted on: 2006/5/21 2:16
NC Kid RE:LT-1 won't start after gasket replacement
North Carolina
1671 Posts
That happened to me too times. The first time a fuse blew out. Second time, the rotor button metal piece snapped off...Took me a while to figure it out.
Posted on: 2007/1/15 21:01
