160 user(s) are online (140 user(s) are browsing Forums)
josephf31 Extended antenna height?
New Jersey
375 Posts
How tall is your extended power antenna?
On my 1991 Coupe it is almost 24" from the fender to the tip of the fully extended antenna; I'm not sure if this is the full length or not, can someone out here tell me the height of their fully extended factory power antenna?
Thanks all!!
Posted on: 2008/6/9 1:53
pianoguy Re: Extended antenna height?
My '96 must've answered one of those ads for enlargement - it's about 30 1/2", 4 sections ;-)
Posted on: 2008/6/9 2:25
josephf31 Re: Extended antenna height?
New Jersey
375 Posts
I need some of that for mine!
I am pretty sure that one of the sections is not extending on my antenna. I have a replacement mast and ribbon, but was not able to remove the existing mast/ribbon.
I tried (gently and not so gently) pulling up on the mast after removing the rubber body grommet and the hold down nut, but could not get it out.
I assume the ribbon/mast is broken which is why it won't fully extend, don't see why I would need to replace the whole antenna, correct?
Have looked up FAQs etc on mast replacement but none address this issue...any tips/advice?
Thanks!
Posted on: 2008/6/9 17:43
bogus Re: Extended antenna height?
yank the sucker. It can be tight.
Posted on: 2008/6/11 5:02
Z51 Re: Extended antenna height?
OREGON
127 Posts
mine don't go up, and i made it fo that
Posted on: 2008/7/15 1:40
1990 roadster
