josephf31 | Extended antenna height? | ||
How tall is your extended power antenna?
On my 1991 Coupe it is almost 24" from the fender to the tip of the fully extended antenna; I'm not sure if this is the full length or not, can someone out here tell me the height of their fully extended factory power antenna? Thanks all!! |
Posted on: 2008/6/9 1:53
2002 Magnetic Red C5 6 spd LS1 convertible |
pianoguy | Re: Extended antenna height? | ||
My '96 must've answered one of those ads for enlargement - it's about 30 1/2", 4 sections ;-)
Posted on: 2008/6/9 2:25
josephf31 | Re: Extended antenna height? | ||
I need some of that for mine!
I am pretty sure that one of the sections is not extending on my antenna. I have a replacement mast and ribbon, but was not able to remove the existing mast/ribbon. I tried (gently and not so gently) pulling up on the mast after removing the rubber body grommet and the hold down nut, but could not get it out. I assume the ribbon/mast is broken which is why it won't fully extend, don't see why I would need to replace the whole antenna, correct? Have looked up FAQs etc on mast replacement but none address this issue...any tips/advice? Thanks! |
Posted on: 2008/6/9 17:43
bogus | Re: Extended antenna height? | ||
yank the sucker. It can be tight.
Posted on: 2008/6/11 5:02
Z51 | Re: Extended antenna height? | ||
mine don't go up, and i made it fo that
Posted on: 2008/7/15 1:40
1990 roadster |
