203 user(s) are online (75 user(s) are browsing Forums)
j3studio [Original Look & Better Functionality] Clueless About Wear Items On A Distributer
[1985/A4/very stock]
Following a couple of troubleshooting diagrams in the Helms lead to the distributer.
I know nothing beyond the absolute basics about distributers.
Here's the question:
are there wear items in the distributer assembly other than the distributer cap (it's original and NCRS judged) that would be reasonable to replace?
Posted on: 2008/6/17 14:52
CentralCoaster Re: [Original Look & Better Functionality] Clueless About Wear Items On A Distributer
Cap, rotor, coil, and ignition module are standard replacement items. The cap and rotor are the only things that really wear though.
The rest should last the life of the car.
As for your NCRS, the replacement coil covers and maybe the caps too are different than your original, they have 3 screws vs 2.
Posted on: 2008/6/17 16:18
j3studio Re: [Original Look & Better Functionality] Clueless About Wear Items On A Distributer
That's what I was thinking - is it psychotic just to replace the rotor?
Posted on: 2008/6/17 16:29
Doesn't hurt. Try cleaning up the terminals under the cap at the very least with a wire brush or pencil eraser if you're going to reuse it.
Posted on: 2008/6/17 19:06
Thanks!
Posted on: 2008/6/17 19:33
bogus Re: [Original Look & Better Functionality] Clueless About Wear Items On A Distributer
20878 Posts
The gear on the bottom of the distributor can fail.
Posted on: 2008/6/17 22:28
Notorious Re: [Original Look & Better Functionality] Clueless About Wear Items On A Distributer
Shaft bushings used to be replaceable but I don't know if they still are as in your case. Probably just have to replace the distributor if the shaft gets too sloppy now. I used to replace bushings frequently though on older points type and even some earlier electronic distributors.
Posted on: 2008/6/17 22:37
I hate sporks...
Well, I guess the engine block could split in half too...
Posted on: 2008/6/18 19:27
Behave!
Posted on: 2008/6/18 20:13
