197 user(s) are online (145 user(s) are browsing Forums)
red_johnny Welcome vetteblondie
Post often and play the games!
Posted on: 2007/4/4 13:41
vetteblondie RE:Welcome vetteblondie
Jonesboro, AR
4650 Posts
Hi! Thanks for the warm welcome! Found out about you guys on MySpace.
Posted on: 2007/4/4 15:27
red_johnny RE:Welcome vetteblondie
Not to shy you away from here but there is another place to go if you wanna have alot of fun. Over at www.domesticmisfits.net I am a member there and a few other places. The misfits well, are just that. We rag on each other to no end but all in fun. Check us out there but dont be a stranger here either
Posted on: 2007/4/4 16:28
Jonesboro, AR
4650 Posts
Thanks for the info! I am trying to learn more about my car - have learned lots already and am doing a little of my own work but want to do a lot more. Found some great info in here. I'll have a look-see at the other site you mentioned!
Posted on: 2007/4/4 16:33
Ok, the misfits is mostly where we at Corvetteforum.com have made ourselfs....um, unwelcome I guess. If your not a corvette purest then you may not fit well at CF but they have a wealth of knowledge. Between there and here you will learn a ton. Now the misfits love to play and joke and bash so if you like to do that then
Posted on: 2007/4/4 16:57
Oh yeah, if you vist the misfits go to "The Pits" and you will see what I mean about bashing and having fun You may have to be a member to do that though now that I think about it. Its worth it, after all, its free.
Posted on: 2007/4/4 17:03
Jonesboro, AR
4650 Posts
Yep, been there, saw that and now have the T-shirt...registered a bit ago, so now I'm in bizniz.... Thanks!
FYI, http://www.obd-codes.com and alldatadiy.com help me alot also.
Posted on: 2007/4/4 17:39
Alcee1 RE:Welcome vetteblondie
Los Angeles
277 Posts
Welcome Blondie, hope to see you around
Posted on: 2007/4/5 20:45
