181 user(s) are online (140 user(s) are browsing Forums)
GRIS, more...
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
f451degrees exhaust
anacortes, wa
9 Posts
any advantage to my 91 l98, stock, to replace the exhaust with a stock one off a lt1?
see ya on the road
Posted on: 2007/4/29 19:23
see ya on the road
NC Kid RE:exhaust
North Carolina
1671 Posts
I doubt it....It will help yea because the L-98s exaust sucks pretty bad...3 catalytic converters was dumb plus age has taken a tolll on it and if your cats are clogged....eww.
Posted on: 2007/4/30 3:16
Alcee1 RE:exhaust
Los Angeles
277 Posts
Nope, get you some headers with 3" pipe all the way back and some good after market mufflers.
Posted on: 2007/4/30 14:41
NC Kid RE:exhaust
North Carolina
1671 Posts
Other option is 2.5 true dual muffler eliminators.....Longtube headers by hooker....
Posted on: 2007/5/1 0:48
bogus RE:exhaust
actually, yes.
The L98 system SUCKS WIND. It has a pair of precats, and a central cat.
I feel that more than half of the 50 hp found in the LT1 came from the better exhaust.
The dual cats of the LT1 have much better flow characteristics than the L98 cats.
The only question is the O2 sensor... the LT1 system has one on each bank. the L98 has only one.
I don't like the idea of "true duals." The problem is that each bank is running independantly. Duals are fine, but at least install an xpipe to help scavaging.
Posted on: 2007/5/1 2:57
Notorious Re: exhaust
see ya on the road
Yes, the L98 system is crap. Considering how cheaply the LTx systems can be picked up, you'd be hard pressed to achieve more bang for the buck. If you run across an LT4 system, it already has a crossover. If you use an LT1 system, add an X-pipe or a crossover for maximum benefit.
Posted on: 2007/5/5 2:49
I hate sporks...
