199 user(s) are online (159 user(s) are browsing Forums)
1st Gear: 2.48
2nd Gear: 1.48
- 13 Bolt ...
joesroad Yokohama Tires
central florida
16 Posts
Anyone have any experience with yokohama tires? I know where I can get a sweet deal on these.
Posted on: 2007/2/28 23:45
bogus RE:Yokohama Tires
They are really good tires. You won't go wrong.
Posted on: 2007/3/1 7:08
Rick1990 Yokahoma tires
Troy NY
7 Posts
I just baught a set because I couldn't afford the Goodyears at more than double the price. Money is tight right now.. Great tires so far. I put them on last week. For $115.00 a tire, you can't go wrong.. I won't be buying anything else in the future except yokahamas I got mine at the tirerack.
Posted on: 2007/4/21 14:03
strapp RE:Yokohama Tires
3 Posts
Which Model of Yokohama Tires did you buy??
Posted on: 2007/7/24 13:32
Notorious RE:Yokohama Tires
Good question. It's hard to offer an opinion by brand only. Also knowing the OPs specific needs and purposes would be required to offer any advice of significance.
Posted on: 2007/7/28 1:55
I hate sporks...
3 Posts
I have a 90 coupe 77k. Just dropped $2800 to replace head gaskets and assorted other work. It now runs great but tires are the next issue.
I am a weekend driver and put 3000 mile a year on the car. Don't drive in the rain if I can avoid it.
Handling, ride comfort and noise level are my main thing. And, ofcourse price. Also the car tends to sit in the garage more then it's driven. How do I avoid flat spots on the tires??
Posted on: 2007/7/31 14:48
I'm not going to suggest any tires simply because tire noise is something that I just don't pay attention to. I've had quite a few different kinds of tires on mine and I could tell you a lot of things about any of them, but noise isn't one of them.
They do make some things that you can park on that are supposed to prevent tire flat-spotting in cars that sit. Once again, never been a concern for me. Mine is driven constantly.
Posted on: 2007/8/1 22:05
I hate sporks...
3 Posts
Ok fair enough
How about a recommendation based on your experience
Posted on: 2007/8/1 22:42
Ok fair enough
No problem. The best handling street tire I've had on my car was the Kumho MX. I found it to be as good, and even more predictable, than the Goodyear F1 Supercar which is another great tire I've tried. And they're much less expensive too, needless to say. The Kumho doesn't have a high wear number, but for your purposes, it'll likely harden with age before you can wear it out. And although rated as a dry and warm weather tire, as long as the tread is still pretty good, it won't be scary should you ever be caught in the rain.
Posted on: 2007/8/2 21:28
I hate sporks...
