1987c4red | water on passenger floor | ||
Help before I drown. Water on pass, side floor. Ran water test with hose in screen below windshield and in cover next to wiper pivot. How is the water getting into the pass side?
Posted on: 2008/8/3 0:36
Matatk | Re: water on passenger floor | ||
If I recall correctly there is a drain tube that can get clogged. I'd check for that. If you find it clean it out with compressed air or a straightened coat hanger.
I'm sorry I can't tell you exactly where it is right now. Someone should chime in. Matthew |
Posted on: 2008/8/3 1:21
biggrizzly | Re: water on passenger floor | ||
Make sure it don't smell like engine coolant! that could mean a real headache for you. However more than likely it is a clogged condensate drain. I'll take a look in my FSM in the morning and tell you where mine is in the 94, and it should be similiar in yours. If it smells like coolant you probably got a leaking heater core, and that aint going to be fun.
Posted on: 2008/8/3 3:20
1987c4red | Re: water on passenger floor | ||
Where is the drain tube located?
Posted on: 2008/8/3 17:47
bogus | Re: water on passenger floor | ||
look under the car. It's inboard of the right front tire... it comes down the firewall a bit.
Posted on: 2008/8/3 18:13
Thanks I will give it a look tonight
Posted on: 2008/8/4 19:37
