285 user(s) are online (189 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
1987c4red water on passenger floor
SW Florida
40 Posts
Help before I drown. Water on pass, side floor. Ran water test with hose in screen below windshield and in cover next to wiper pivot. How is the water getting into the pass side?
Posted on: 2008/8/3 0:36
Matatk Re: water on passenger floor
If I recall correctly there is a drain tube that can get clogged. I'd check for that. If you find it clean it out with compressed air or a straightened coat hanger.
I'm sorry I can't tell you exactly where it is right now. Someone should chime in.
Posted on: 2008/8/3 1:21
biggrizzly Re: water on passenger floor
Make sure it don't smell like engine coolant! that could mean a real headache for you. However more than likely it is a clogged condensate drain. I'll take a look in my FSM in the morning and tell you where mine is in the 94, and it should be similiar in yours. If it smells like coolant you probably got a leaking heater core, and that aint going to be fun.
Posted on: 2008/8/3 3:20
1987c4red Re: water on passenger floor
SW Florida
40 Posts
Where is the drain tube located?
Posted on: 2008/8/3 17:47
bogus Re: water on passenger floor
look under the car. It's inboard of the right front tire... it comes down the firewall a bit.
Posted on: 2008/8/3 18:13
SW Florida
40 Posts
Thanks I will give it a look tonight
Posted on: 2008/8/4 19:37
