mojo92 | RPMs acting retarded | ||
Also when we hooked the rpm back up it has goten retarded !! When you push the gas the rpm stays down and when you let off it goes all the way to the top and stays there til you give it gas again. push gas it goes down , let off it goes up and stays there .
Posted on: 2008/8/3 23:45
bogus | Re: RPMs acting retarded | ||
that sounds like an issue with the tach filter. double check the wiring.
Posted on: 2008/8/4 0:12
BrianCunningham | Re: RPMs acting retarded | ||
"also"???
Where's the other half??? |
Posted on: 2008/8/4 15:46
mojo92 | Re: RPMs acting retarded | ||
Heres the other half........We just got the motor back in the car after a rebuild and now the motor is running rich. We think that one of the injectors is bad. We took it lose and the tune did not change like it did with the others. #1 injector I thank, would this make the motor run that way ?
Posted on: 2008/8/5 3:35
gee... I wish you would put all the issues into one thread... it would make fixing them that much simpler.
Posted on: 2008/8/5 4:04
MK 82 | Re: RPMs acting retarded | ||
This guy is a few participles short of a full sentence!
Posted on: 2008/8/5 18:37
96 CE Roadster LT4 |
