259 user(s) are online (196 user(s) are browsing Forums)
josephf31 Next problem -- fuel guage always empty
New Jersey
375 Posts
I just replaced the fuel sending unit, still have an always empty fuel guage; the cluster is good, all bars light up at start -- I did have some trouble getting the unit into the tank, is it possible something is binding or broken?
Also odd is that sometimes (no regular pattern) the fuel guage will go up to 3 or 4 bars, stay there for a while, then go back to zero/reserve...
One of these days I hope to be able to just get in and drive her! Thanks all...
Posted on: 2008/8/14 14:15
Mekanic Re: Next problem -- fuel guage always empty
Tampa Bay Florida
827 Posts
if you just replaced the sending unit, my money would be on a wiring issue somewhere.
But I'm honestly at a loss.
Posted on: 2008/8/14 14:36
~Rich
Polo LT4
FATED Re: Next problem -- fuel guage always empty
Texas
157 Posts
I had a similar problem. This is a flimsy sender and if you had trouble getting it back in you may have bent the contact or it fell apart. Mine started doing just like you said and it had just fell apart. Reassembled and put back in. Been working ever since.
Posted on: 2008/8/16 1:58
josephf31 Re: Next problem -- fuel guage always empty
New Jersey
375 Posts
That's kind of what I was thinking, it was not easy for me to get it back in; is it supposed to drop straight in without twisting? If so it really scraped the sides of the opening...
Also if the float arm portion is damaged or broken, is that available as a separate part from the rest of the unit?
Last thing, I used a new gasket when I put this unit in, since it's hasn't been long it should be OK to reuse this practically new gasket, no?
Thanks again all!
Posted on: 2008/8/16 5:30
Tampa Bay Florida
827 Posts
I'd say youd be fine reusing the gasket
Posted on: 2008/8/16 8:13
~Rich
Polo LT4
jsup Re: Next problem -- fuel guage always empty
1778 Posts
Don't be so cheap, fill the tank.
Posted on: 2008/8/16 13:20
Texas
157 Posts
This is a step by step repair.
doc Fuel Gauge Sending Unit Repair If your C4.doc Size: 0.00 KB; Hits: 122
Posted on: 2008/8/16 18:26
Matatk Re: Next problem -- fuel guage always empty
Nice instructions, thanks for posting. I saved 'em for future reference.
Posted on: 2008/8/17 1:26
