161 user(s) are online (119 user(s) are browsing Forums)
Also known as NHMS....
1987c4red Code 33 diagnosis
SW Florida
40 Posts
I started out with a code 36 and ended up with a 33. New intake gaskets, EGR valve, blocked off injector, checked the TPS adjustment (.67), Cleaned throttle body, new IAC and now it throws a code 33. New plugs, wires, cap rotor, Anybody gone thru this road before? Advise needed badly. Before I replace ECM I want to be sure. MAF is clean and replaced relays. Its startin to piss me off!
Posted on: 2008/8/16 21:59
1987c4red Re: Code 33 diagnosis
SW Florida
40 Posts
Forgot the important info 87 C4
Posted on: 2008/8/16 22:02
Qack Re: Code 33 diagnosis
274 Posts
Posted on: 2008/8/17 1:00
Matatk Re: Code 33 diagnosis
22811 Posts
That looks like a good article. Others have had problems with those codes from poor connections. I'd check those first. Do you have a FSM for the step by step diagnosis?
Posted on: 2008/8/17 1:39
SW Florida
40 Posts
Yes on the manual question. Still pulling my hair out.....what left anyway!
Posted on: 2008/8/19 16:28
