207 user(s) are online (128 user(s) are browsing Forums)
« 1 (2)
crash Re: Acceleration trouble
WRIGHT CITY MO 63390
977 Posts
ahhh morale of the story when replacing fuel pump always replace fuel filter wwe do all the time at the shop
Posted on: 2008/10/9 1:32
Schrade Re: Acceleration trouble
Strange... Seems like a fuel pressure test pedal down gauge taped to the windshield would have revealed insufficient pressure / blockage of fuel flow enrichment.
Glad you got it runnin'...
jpg  FPTests.jpg (117.40 KB)
1687_48ed756114a8a.jpg 434X646 px
Posted on: 2008/10/9 3:07
jimmers Re: Acceleration trouble
Winnipeg, Manitoba Canada
211 Posts
The filter was replaced with the fuel pump. It's only about a month old.
Posted on: 2008/10/10 18:44
211 Posts
Thanks! My fuel pressure gauge did show a huge drop in pressure at idle. Giving it gas would not make a difference.
I've never seen a broken fuel filter before!
Posted on: 2008/10/10 18:46
211 Posts
Matatk wrote:
jimmers wrote:
Well it turns out my fuel filter was the culprit. Something inside broke and when under pressure blocked the line. Again thanks for everyones help!
Thanks for the update! Good to know the solution to problem for future reference.
I agree! I hate when people don't follow up in their thread with the solution.
Posted on: 2008/10/10 18:47
« 1 (2)
