342 user(s) are online (286 user(s) are browsing Forums)
Steve40th Sway bars, Did GM ever offer or sell 32mm Solid C4 sway bars, front
1114 Posts
I purchased my sway bars many years ago from Jeff Kopp, and I have the 32 S 26 S set up. But no where on the chart for suspensions is there a 32S sway.
Just curious, as I have measured it and it is a little over 1.25 inches, which is 32mm.
I lost all paperwork and logs years ago (2001) when I moved, so I am curious how I got this bar from Jeff.
Posted on: 2008/11/10 4:37
Ko'u ohana aia ku'a ikaika
Notorious Re: Sway bars, Did GM ever offer or sell 32mm Solid C4 sway bars, front
The biggest GM ever offered was a 30mm front. I've got a 32mm too but it's from VB&P.
Posted on: 2008/11/10 6:18
I hate sporks...
bogus Re: Sway bars, Did GM ever offer or sell 32mm Solid C4 sway bars, front
Good question... but I prefer hollow. They work exactly the same, but are lighter.
Posted on: 2008/11/10 6:49
Steve40th Re: Sway bars, Did GM ever offer or sell 32mm Solid C4 sway bars, front
1114 Posts
I AM SO STUPID
Well guess what, GMS Quality assurance isnt all that either.
The bushing is 30mm. I squeezed it real hard and it is 30mm. There is a piece of rubber where they cut the bushing to allow you to put around the bar, and when they cut it was causing it to not compress correctly.
I feel like an Opti SPark
Posted on: 2008/11/10 19:08
CentralCoaster Re: Sway bars, Did GM ever offer or sell 32mm Solid C4 sway bars, front
You're supposed to measure the bar, not the bushing dummy.
Posted on: 2008/11/10 19:40
1114 Posts
Well anyways, here are the new stiffer OEM bushings.
The poly bushings are offset to pull the bar forward. Wonder why?
[IMG]http://i33.photobucket.com/albums/d80/Steve40th/DSCF0074-1.jpg[/IMG]
Posted on: 2008/11/10 19:51
To clear coilovers? I don't know.
Posted on: 2008/11/11 0:22
