pr0zac | lc-1 wideband question | ||
i have installed my wideband and done everything as per instructions and it won't read anything but 9.9 after it heats up. even if the car is off..i have tried to recalibrate, i went so far as to disconnect everything and do it again and that is all it reads..
Posted on: 2008/11/24 0:25
C4DERF | Re: lc-1 wideband question | ||
At the expense of sounding dumb, what :didimiss: is an lc-1 wideband controller or better, what does it do and what are the benifits? My :google: search showed up with a device from titan motorsports and the best I can tell is it has something to do with the fuel/air mixture ratio and can be applied to individual fuel injectors(?). Thanks, I guess I need a little more education...
Posted on: 2008/11/24 3:18
94 C4 LT1 A4 Polo Green w/Lt Beige Coupe ![]() [IMG]http://i151.photobucket.com/albums/s150/c4derf/CasualCorvettes-SonicAug07011.jpg[/IMG] |
Mekanic | Re: lc-1 wideband question | ||
sounds like you may have gotten a bad sensor, give them a call and see what they come up with. Dumb question but you are using one of their wideband sensors right? not just the box |
Posted on: 2008/11/24 3:21
jsup | Re: lc-1 wideband question | ||
The stock 02 only shows MV output. A wideband shows actual AF ratio. It's a tool for tuning to get the AF ratio where you want it. |
Posted on: 2008/11/24 3:23
