232 user(s) are online (180 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
BrianCunningham HDTV reception
For those doing "over the air" reception have you checked it yet?
Not quite as strong as the old analog signal is it?
What I can't figure out is that I recieve all the digital channels in our area downstairs, but the TV's upstairs can't get the all.
Weird!!!
The only thing I can figure out is that the power lines outside are at the same elevation.
Also the router is upstairs, but that's on a different fequency.
Looks like I'll need a better antenna.
I'm thinking of making one, it's not like I'm going to put it where anyone can see it.
http://uhfhdtvantenna.blogspot.com/
Posted on: 2008/12/13 11:55
BrianCunningham Re: HDTV reception
Well if I do buy one, I like the one here that made to look like a picture frame
Posted on: 2008/12/13 12:08
pianoguy Re: HDTV reception
We bought a small LCD to have out on the deck last summer, so we tried the over-the-air reception. I bought a small powered antenna, and the signal was pretty good. But my wife made me run a cable out there anyway, as the Twins games are only available on cable.
Posted on: 2008/12/13 15:59
bogus Re: HDTV reception
I suspect that digital signals are a little more line of sight dependant.
Posted on: 2008/12/14 19:17
Well I just got back from the Ripoff Shack
Twice.
Tried one of those omnidirectional antennas you find on boats/RVs that actually made it WORSE
So I went out and bought one of the 160in Christmas tree Antennas
Trying to figure out how to get it in the attic now
Posted on: 2008/12/14 21:28
Twice.
Posted on: 2008/12/14 23:08
I boxed it up and brought it back.
Something is definitely jamming the channels upstairs.
Like I said downstairs is AOK.
I guess I'll have to watch those stations downstairs
