| CentralCoaster | NFL Playoff pool... step inside! | ||
Pool is closed, no more buy-ins. Superbowl winner gets double points. Winner take-all.
I attached an excel file with the bracket and picks so you can calculate the scores yourself, or play with different outcomes. Final points (add double points for Steelers for superbowl win): 87 CentralCoaster 77 bigrizzly 75 RUBY9246 72 SpectatorRacing 72 JrRifleCoach 65 Randyj75 62 bogus |
Posted on: 2008/12/8 17:14
Transfer
| JrRifleCoach | Re: NFL Playoff pool... step inside! | ||
pm sent
Posted on: 2008/12/8 20:11
Transfer
| CentralCoaster | Re: NFL Playoff pool... step inside! | ||
To who?
Posted on: 2008/12/8 23:21
Transfer
| Randyj75 | Re: NFL Playoff pool... step inside! | ||
PM sent to you.
Posted on: 2008/12/17 0:39
Transfer
Come on people, let's get busy...
Posted on: 2008/12/17 1:00
Transfer
Hey, what do you guys think about throwing in some bonus points for picking top players each week, or superbowl mvp, stuff like that?
Too complicated? |
Posted on: 2008/12/17 1:07
Transfer
| SpectatorRacing | Re: NFL Playoff pool... step inside! | ||
As a separate pool, perhaps, but not as part of this one.
Posted on: 2008/12/17 20:04
aka Scaryfast |
Transfer
| biggrizzly | Re: NFL Playoff pool... step inside! | ||
OK, I'm a little slow.
I haven't played this kind of pool before. Someone explain this a little bit better. I'm in... just need to know the strategy here. |
Posted on: 2008/12/17 22:40
Transfer
There are 12 teams in the playoffs.
You assign numbers 1 through 12 to the teams. Each time a team wins, you get that many points. Total points wins. So... if you think that Denver can go all the way, you probably want to give em 12 points. If you think the Bucs will lose their first game, give em 1 point. The trick, is the top 2 teams in each conference have a first round bye.... so this means if you give 11 points to your precious Giants, you still get zero point from them in the first round. My first post shows a picksheet for a previous year. Now I'm attaching a results sheet from that season. You can see the small grey number is what each player picked for each team. Wins for each team are tallied on the left, and the resulting points calculated and totaled. The tiebreaker I used was total points in the superbowl. |
Posted on: 2008/12/17 22:51
Transfer
The best strategy I can offer is you want your high point teams to go as far as possible. So don't put your 12 point team against your 11 point team in the first round, because one will lose. Also try and avoid loading all your points on the top seeded teams, it rarely works because you don't get those points on the bye week and end up starting in a hole. You can still win this way if all the favorites win, but you're screwed if they don't.
Most people fill in the bracket a few different ways on how they think it will turn out and then assign points accordingly. And of course, the 2nd round matchups change depending on which teams win the first round. |
Posted on: 2008/12/17 22:57
Transfer
5 of the 12 seeds were decided last weekend.
After Sunday I will publish the pick sheets. Then I'll just need your picks (with payment) before the first playoff game on Jan 3rd which is [b]10 DAYS FROM NOW[/B]. NFC 1. NYG 2. 3. 4. AZ 5. 6. AFC 1. TEN 2. PIT 3. 4. 5. IND 6. CAR and ATL are in, but not seeded yet. MIA, NE, NYJ, BAL, DEN, SD, DAL, PHI, CHI, MIN, TB are all up for the last 5 spots. |
Posted on: 2008/12/24 23:12
Transfer
Sent a PM and posted here.
If you guys are afraid of getting wupped again just say-so. ![]() |
Posted on: 2008/12/25 6:13
Transfer
Ok folks, the bracket is set!
I updated the top post with the official picksheet. I just need everyone's picks and payments before games start on Saturday. I'm working on mine right now. Steve, I'm not receiving any of your PMs for some reason. You should have my contact info from the last pool. I'll PM you anyways. |
Posted on: 2008/12/29 21:40
Transfer
Gotcher widgets.
Posted on: 2008/12/30 16:56
Transfer
| RUBY9246 | Re: NFL Playoff pool... step inside! | ||
If its not to late, I am in.
Will send PayPal tonight. I will PM Picks also. |
Posted on: 2008/12/31 14:24
Transfer
I'll get mine together tonight or tomorrow depending on what's going on around the house for New Years. Nonetheless you will have it before Saturday.
Posted on: 2008/12/31 14:47
Transfer
| bogus | Re: NFL Playoff pool... step inside! | ||
I'm in!
Posted on: 2008/12/31 15:38
Transfer
PM with Picks and PP sent.
Posted on: 2008/12/31 15:52
Transfer
Updated.
Posted on: 2009/1/2 4:36
Transfer
bump.
Time's running out! |
Posted on: 2009/1/2 22:45
Transfer
Kevin, PM sent.
Posted on: 2009/1/3 1:07
Transfer
PM sent.
Posted on: 2009/1/3 2:25
Transfer
Randy, check your PMs, there's problems with your picks... |
Posted on: 2009/1/3 2:28
Transfer
bump. Posted everyone's picks in top thread.
Also put an excel file for the impatient ones, it will calculate the score for you. |
Posted on: 2009/1/3 21:13
Transfer
Thanks for the updates...I can't believe I'm leading with Indy out. Won't be long, though. Good thing everyone had SD ranked low!
Looks like Pittsburgh is going to make or break me. |
Posted on: 2009/1/5 15:46
aka Scaryfast |
Transfer
Check on the points you've got on a team vs. other players and that'll tell you which teams you need.
For you, Arizona and Philly are important, but if the Steelers win too many, you'll be hurting. |
Posted on: 2009/1/5 17:16
Transfer
Jon is running away with it!
Epic failure by Jake Delhomme. 6 turnovers by one guy? That has to be some sort of playoff record. |
Posted on: 2009/1/11 4:22
Transfer
Man, what a game! Well, for Arizona. I had a gut feeling about them, wish I had picked them as an 8 or 10. I listened to too many sportswriters and tempered my enthusiasm.
So we're back to Pittsburgh...here's to hoping they fail. |
Posted on: 2009/1/11 16:04
aka Scaryfast |
Transfer
I am still shocked... the Eagles won. I can't believe it.
I hoped, yes, but am still surprised when it happens. |
Posted on: 2009/1/11 21:34
Transfer
Yup, that really burned a few people.
With the Giants loss, I need Pittsburgh to go all the way. Hate to ruin the fun, but some of you guys are already eliminated. |
Posted on: 2009/1/12 0:48
Transfer
Especially with a veteran quarterback. I guess nobody gave them a chance without a running game. They do have some good backs, they just never need to use em.The younger quarterbacks haven't done much. |
Posted on: 2009/1/12 0:51
Transfer
I can't believe the way Carolina when into the tank. I guess I should have been suspect of them after the Giants beat them.
Oh well,lets go Birds |
Posted on: 2009/1/14 0:36
Transfer
Crap, I thought you were bogus.
Damn bandwagoners and your fancy avatars. Ok I admit, I'm just jealous. |
Posted on: 2009/1/14 1:41
Transfer
Bow chicka bow-wow... go Steelers! Had Baltimore won, Jon would've clinched it.
My arm is sore from patting myself on the back. Actually I didn't even watch the game. If it isn't obvious by now, here's where sit: Steelers win = I win Cards win = Spectator wins Exciting nail-biting game with good commercials = everybody wins. Sorry to ruin the fun. Basically none of us had good picks. I entered another pool with these same picks and finished close to last. Everyone has a shot to win it back in the upcoming fantasy nascar season(s). |
Posted on: 2009/1/19 18:13
Transfer
Go cards!
Who'd have ever thought that I (or anyone not in Arizona) would be saying that? Plus a victory would seal #13's entry into the hall of fame. I'd like to see the old guy make it. He may be the only NFL player older than me. |
Posted on: 2009/1/20 18:41
aka Scaryfast |
Transfer
When reviewing my number picks now, I really screwed up on Philly!
Posted on: 2009/1/20 22:47
Transfer
In these pools the winner typically ends up with over 100 points, and that's without the bonus superbowl points I added!
So that should give you an idea how far off we are. I knew the Titans would suck, but the rest of this is a surprise to me. |
Posted on: 2009/1/21 2:03
Transfer
So who won, CC?
Posted on: 2009/2/3 23:07
Transfer
Yeah. Totally rigged. Lame.
I think next time I'll have to put a 1,2,3rd place. These tend to get decided early and eliminat most of the players. The other pool I was in was decided before the conference championship games even started. |
Posted on: 2009/2/3 23:51
Transfer
Next year I think I'll go to the indian casino and buy a dinner.
Posted on: 2009/2/4 5:16
Transfer
This year I'm going to buy 7 dinners and let 6 of them get cold. |
Posted on: 2009/2/4 5:51
Transfer
Hey do I get a bonus for almost nailing the total points scored in the big game?
Posted on: 2009/2/4 16:19
aka Scaryfast |
Transfer
NFL POOL 2008 .xls
Transfer
NFL POOL 2006 .pdf
