jsup | Changing ABS | ||
What is the story with changing out ABS Pads? Is there a check valve or a solenoid or something that needs to be held open?
Posted on: 2008/12/19 22:41
BrianCunningham | Re: Changing ABS | ||
Changing the pads? No
Bleeding the brakes? The older cars have a bleeder screw on the ABS unit. |
Posted on: 2008/12/19 22:45
