173 user(s) are online (137 user(s) are browsing Forums)
jsup Changing ABS
1778 Posts
What is the story with changing out ABS Pads? Is there a check valve or a solenoid or something that needs to be held open?
Posted on: 2008/12/19 22:41
BrianCunningham Re: Changing ABS
Changing the pads? No
Bleeding the brakes?
The older cars have a bleeder screw on the ABS unit.
Posted on: 2008/12/19 22:45
