191 user(s) are online (72 user(s) are browsing Forums)
Schrade 4L60e TCC slippage...
Items that can change unlock/lock thresholds:
a) A/C clutch engaged
So if A/C clutch 'in or out' is integrated into TCC lockup mode, how could 'in' cause excess slippage?
What's the definition of slippage?
The only time in the last 2 years I tripped an SES for TCC slippage was stop n go traffic, A/C on max, fan blower on max.
'98 GMC Jimmy.
http://diy-efi.org/gmecm/papers/tcc.txt
Ideas?
Posted on: 2008/12/22 22:45
pr0zac Re: 4L60e TCC slippage...
a bad signal to the ecm?
Posted on: 2008/12/26 17:49
Schrade Re: 4L60e TCC slippage...
That's what I'm guessin'.
Except for 183k on the tranny. Still shiftin' smooth, except stop n go, A/C on, fan on max. If it's worn, why no performance issues except for those circumstances?
Posted on: 2008/12/29 19:17
