144 user(s) are online (108 user(s) are browsing Forums)
[IMG]http:/...
movnviolation Miniram users, need your help
Hesperia, Calif
188 Posts
Where are you rerouting your heater hose to after cutting the lower plate of the throttle body? I am looking at the front of the manifold where I have a plug.
Any pics, Thanks!
Posted on: 2008/12/28 6:22
Mods
anesthes Re: Miniram users, need your help
Boston, MA
Any pics, Thanks!
There should be one fitting on the manifold to the heater core. One fitting on the water pump to the heater core. The bleeder in the rear gets blocked off. The coolant to the tb get's deleted.
The other threaded hole in the miniram is for the CTS.
-- Joe
Posted on: 2008/12/28 14:43
