106 user(s) are online (43 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
dougs91 Possible Starter Issues?
Olalla Wash.
22 Posts
My stock 91 auto is ill!! Has been running great(daily driver) with 150k until yesterday when getting off work I get in to start the car, turn the key and hear a grinding noise from down near the starter.Noise last for 1 sec.then seem to bind,then nothing. This "grinding" almost is a sound of metal on metal "crunch". Got home late due to tow, and now back at work so haven't had a chance to look. Any thoughts?? Thanks,Doug
Posted on: 2009/2/19 18:13
1991 QBlue L98
dougs91 Re: Possible Starter Issues?
Olalla Wash.
22 Posts
FOLLOW-UP, Local mechanic stopped by to have a look and he pulled #3 plug and #7 plug and antifreeze came pouring out along with bits of metal shavings.This engine was rebuilt 4 yrs.ago,and it appears to be toast again!!! I'm not putting another penny into this 18 yr.old car. Parts anyone?? Doug
Posted on: 2009/2/19 20:32
1991 QBlue L98
BrianCunningham Re: Possible Starter Issues?
Ouch!
Posted on: 2009/2/19 20:50
dan0617 Re: Possible Starter Issues?
Well, sounds like your starter is fine......
Is there 150K on the rebuilt motor or on the car?
Too bad that a 4 yr old motor is toast. I hate to see you part it out. Have you considered buying a used motor and installing it yourself? Could be a fun learning experience.
Or you could let all us motorheads talk you into building it up into a serious street machine.
Posted on: 2009/2/19 21:10
Olalla Wash.
22 Posts
Brian, big OUCH!!
Dan, 150xx on the car.I've thought about buying a used motor to rebuild and learn from doing it but, then the extra cost, down time,I just don't know. Like most of us I've got more into this car than it's worth,and maybe it's time to move up in years.I've got to have another Vette!! Doug
Posted on: 2009/2/19 21:51
1991 QBlue L98
TommyT-Bone Re: Possible Starter Issues?
33800 Posts
What cosmetic condition is your 91 in? Motors are just another part albeit a big part. A Crate motor installed locally would minimize down time. What your going to lose plus what your going to spend might make repowering more inviting. Check out your local yellow pages for engine rebuilders and get a price for repair/replacement too.
Posted on: 2009/2/19 22:00
