318 user(s) are online (240 user(s) are browsing Forums)
TommyT-Bone, more...
dougs91 Head Gaskets
Olalla Wash.
22 Posts
Looks like my 91 blew the left side head gasket.Now I've been looking for the correct size gasket and see both the Fel-pro 1010 and 1003 should work?? Also, this engine had a stock rebuild done about 5 yrs.ago if this makes any difference.The more I read about these things, the more confused I become!! Thanks, Doug
Posted on: 2009/2/22 15:55
1991 QBlue L98
CFI-EFI Re: Head Gaskets
Top of Utah
372 Posts
As you have noted, either Fel Pro number will work. There are others as well. Since it had a rebuild, you may want to inspect the old gasket for numbers, etc so you can make the best match with the other side. Also, before you put it back together, take the head to a machine shop to have it checked for warping. They can give it a light mill job if necessary to insure the gasket surface is flat.
RACE ON!!!
Posted on: 2009/2/22 18:50
anesthes Re: Head Gaskets
Boston, MA
Take off other side.. Have both heads checked. Measure deck height at TDC. Install appropriate gasket to get quench. Advance timing a little to make more power.
Personally, if I was down that far and had the money i'd sell the 113 heads and get something better.
-- Joe
Posted on: 2009/2/24 3:29
