224 user(s) are online (191 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
BrianCunningham One way to make minimum weight
http://sccaforums.com/forums/2/347587/ShowThread.aspx#347587
user="tashko"
He doesn't need to worry about pop-up headlights.
That's the MR1.5! [:O]
Canadian MOD class MR2 stripped down as much as the rules permit, which evidently is quite a bit! That's one of the FTD cars at our events and fun to watch.
Posted on: 2009/2/26 18:16
CentralCoaster Re: One way to make minimum weight
Do they even require a windshield?
Posted on: 2009/2/26 18:18
