djxib | VE Master - corrupting BINS | ||
Does anyone have experience using VE Master? I thought I would try it out just to see what changes it made to my BIN, but every time I use it, the reports show a new VE value of 49 across the board plus the BIN gets corrupted.
I'm assuming that I'm missing something (like pointing it at the correct TDF for my BIN), but cant see how to do that. Cheers! |
Posted on: 2009/3/19 17:06
Stl94LT1 | Re: VE Master - corrupting BINS | ||
Hmmm, I've used VeMaster many times without a problem.
Posted on: 2009/3/19 18:34
djxib | Re: VE Master - corrupting BINS | ||
I found a different version today via moates website, that says its $DA2 compatible. (also going to try a program called VEphd). I'll post up here if I'm successful
Posted on: 2009/3/19 23:56
The version I downloaded from Moates has a $8D/ $DA2 / $DA3 switch.. I tried it last night and it did not corrupt the BIN and the resulting VE table looked fine.
So - I'm going to start using it. Cheers! |
Posted on: 2009/3/20 11:02
