165 user(s) are online (94 user(s) are browsing Forums)
Also known as NHMS....
pappyfreebird 1995 trans am lt1
1028 Posts
what temp should the fan come on?
kids sez gits real close to 250 sitting in drive thru,,fan did come fer awhile but then off..anything to worry bout here?
Posted on: 2009/4/17 0:46
bogus Re: 1995 trans am lt1
you need a real temp gauge vs using the analog on the dash.
It should come on at 228 or there abouts.
Posted on: 2009/4/17 1:05
pappyfreebird Re: 1995 trans am lt1
1028 Posts
thanks bog....seems same as i have in the 84 c4,,,ceptin i thought that were a lower one id put in it,,is 84 c4 a 238? by chance
Posted on: 2009/4/17 12:59
that sounds about right... I will have to confirm, tho.
Posted on: 2009/4/17 14:33
BrianCunningham Re: 1995 trans am lt1
It shouldn't see 250
There's something wrong in the system
fan, relay, sensor, etc.
Posted on: 2009/4/17 16:17
1028 Posts
i hafta go have me look see,,,he knows im a freak bout takin care of stuff n kin git purty riled if it were dumb,,,like low on antifreeze etc... so hopefully hes jus a lil extree parinoid
Posted on: 2009/4/17 17:15
1Fast04Vert Re: 1995 trans am lt1
If it is like the 95 vette there are two cooling fans, controlledd by the PCM based upon readings from the ECT sensor on the water pump. The sensor on the right head is for the analog gauge only. Factory program is main fan on at 227-228*F and the aux fan (passenger side) on at 236*F.
Posted on: 2009/4/17 18:01
